fuse under the seat - gk76a
ben2306
- Bike owned: gk76a
guys, there's a total of 5 fuses under my rider seat, saw numbers on them. is there any specification on which number to use for which? or we can just actually plug in any fuse? please advice.
ben2306
- Bike owned: gk76a
Re: fuse under the seat - gk76a
okay, guys. after looking @ the wiring diagram, i saw main - 20amp, the other 3 - 10amp. but i got 5 fuses...
& what will happen if the amp is INCORRECT?! mine is messed up.
Marsbar
There should only be 4 fuses under there. Unless do you have an alarm? ignition should be 20 amp other 3 10 amp. thats whats on mine anyway
RICKNC31
the fuse no 5 is probably a spare and not connected rick
ben2306
- Bike owned: gk76a
okay, just got all the correct fuses replaced. i think my fuse box is not original? cos i saw on bay selling, for gk76a, its a 5 fuse compartment box.
mine, 4 fuse compartment box, then the main fuse is connected with 2 wires sticking out from bottom!!
any kind soul can post a pic of his rider under seat compartment? i hope i can sort that main fuse out. cos i ever travel on the road, halfway, no power! 1 of the wire fell off the leg of the main fuse!
ben2306
- Bike owned: gk76a
guys, i need to know how many fuse should be in the bike & for what? today, i start up my bike & tried pulling out 1 by 1.
1st 1 10amp out, lights gone, engine still runnng.
2nd 1 10amp out, engine stall but neutral lights still have.
3rd 1 20amp out, engine stall, no lights nothing.
as i said i got 5 fuses there, the other 2 is for what?
the 20amp is suppose to be in which 1? 2nd or 3rd?
THANKS! here's a pic of my compartment.
rgvsp
Looks like somebody was monkeying around with the wiring. That yellow 20 amp main should be one of the 4 in the main fuse box. The fuse box holds four fuses with slots for two extras.
ben2306
- Bike owned: gk76a
i need to know the 4 fuses in wiring diagram is for which electrical before i tidy it up. how many fuse should be in use actually? my friend said 1 for ignition, 1 for fan, 1 for lights. of cause 1 20amp, main.rgvsp wrote:Looks like somebody was monkeying around with the wiring. That yellow 20 amp main should be one of the 4 in the main fuse box. The fuse box holds four fuses with slots for two extras.
ben2306
- Bike owned: gk76a
i've figured it out. took out the box to check. the 25amp is out of the box cos the connector below to fuse box broke.
now have to go source for the connector this weekend.
ben2306
- Bike owned: gk76a
this is why the 25amp fuse is out of the fuse box.
the connectors broke off, that's why.
the 4 fuses are all in use, there's no spare fuse.
