M Max Rev Booster/ De Limiter MH40
scottser32
Post by scottser32 »
any one ever use these, any use do they actually work, there only 50 blips which aint to bad whats the difference between this and the CDI thing??
tanuki
Re: M Max Rev Booster/ De Limiter MH40
Post by tanuki »
Blips?
All they do is derestrict, same as a 20p restrictor.
scottser32
ha ya never hear of blips? but do standard cbrs only do about 110? it says these will get them up to 130??
nazzurro_19
Bike owned: Honda NC30
Post by nazzurro_19 »
Basically ya bike is restricted , this box removes it so full speed can be achieved but as said its a fancier resisior in a nice box with a couple connections
Buy the correct resistor solder it in and wallah restrictor removed
Theres guides on ere
scottser32
ah nice one i was fairly confused about the whole thing, one last thing wats the crack with the cdi's are they not restrictors??
nazzurro_19
The cdi is like the brain of the bike the japanese cdi will only allow a certain speed , swap it for a uk cdi and the bike has full power
Im sure another member will clarify but im pretty sure this is correct
scottser32
ah nice one, another point to make the clock is in MPH not KMH but i hear theres two types, a gold one and a blue one the gold one is the unrestricted one, how do ya tell if its gold where do i look??
nazzurro_19
The mph clocks only came on english nc30 so youve either got an english nc30 or a japanese with nc30 clocks
The blue n gold devices you on about are derestrictors they dont come on the bikes you buy em
The blue one goes under the clocks on ya speedo cable
The gold on the gearbox end
They both do same job
scottser32
its an NC29 so would it have NC30 clocks??
Our good man Nazzuro is getting his skills twisted,
Jap restriction is 180kmh - 112MPH
You can fix this in many ways - search on here with speedo restrictor or somthing similar and you'll have enough to put you to sleep.
ref the blue/gold CDIs - dunno, V4s are better either way so I've never got involved :o :whistle: :mrgreen: :ninja:
Should be as obvious as the balls on a dog though eh? Sticker or somewhat?
