Cleaning carbs
Tomzed
Bike owned: Yamaha wr125x and Nc30
Cleaning carbs
Post by Tomzed »
Im currently stripping my carbs down just wondered if anyone had any advice on cleaning them. Or anything I should do while I have them stripped down etc? :grin:
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: Cleaning carbs
Post by hardnutdvd »
i guess that depends on whether the bike was running ok prior to taking them off..
the carb overhaul/jetting thread (the sticky at the top of this section) is full of good info if you think you may need to alter anything...
Tomzed
Re: Cleaning carbs
Post by Tomzed »
Hi mate the bikes been stood for 6years so the carbs. Need a good clean before I attempt to get it running
hardnutdvd
Regular Member
Re: Cleaning carbs
well i would have a read of the carbs thread.
make sure everything is standard and correctly situated in the carbs when their stripped and thats your starting point. if i remember correctly (although i may be wrong) the emulsion tubes need to be in their correct carbs.. 2 have 4 holes, 2 have 5 holes.
the thread will guide you on this :)
one tip i read a lot of is when attempting to get the carbs back on... buy/use a set of RVF rubbers.. it makes refitting a lot easier :)
FJD
Re: Cleaning carbs
Post by FJD »
i would suggest to get them ultrasonic cleaned, that way you get all of the dirt out of it.
I have the equipment and do that frequently, but i guess there will be someone near you as well who can do the job.
thunderace
Bike owned: R6, YZF600R
Re: Cleaning carbs
Post by thunderace »
FJD wrote:i would suggest to get them ultrasonic cleaned, that way you get all of the dirt out of it.
I'm sick of saying this but Ultrasonic cleaning is a waste of time - it DOES NOT clean properly.
iDemonix
Bike owned: '92 NC30
Re: Cleaning carbs
Post by iDemonix »
I've heard nothing but good stories about ultrasonic cleaning, what makes you disagree?
FJD
Re: Cleaning carbs
Post by FJD »
don´t know what your experiences are from, but in the last 5 years i probably had 25-30 motorcycles i bought/sold on again, and typically every 2nd to 3rd of them needed carbs cleaned out, which i did with my two cleaners.
The cleaning depends on the liquid you use, there is special stuff to do it, and it´s not cheap but very well worth the money.
btw: do you know of anything other to clean out all the small passages and bores in a carburator, other than sticking in stuff that does not belong there....
thunderace
Re: Cleaning carbs
I have sat in my workshop a £3500 415v 3 phase heated U/S bath and about £200 worth of U/S fluid. I stopped using it 2 years ago. Even after three or four one hour cycles, fuel ways were still full of crud.
Nowadays I use a large parts bath. If carbs are really bad, I soak them in red diesel (cheaper than white) for 24 hours to dissolve the worst of the varnish. Then I bathe them in a proper parts washing solution. They always come out in pristine condition.
I do about 60 sets of carbs every year.
iDemonix
Re: Cleaning carbs
Post by iDemonix »
2 years? Just collecting dust then?
I'd be extremely obliged to come take that off your hands for a case of beer ;)
