Page 1 of 2
Fitting CBR 600rr caslipers and master cylinder, advice???
Posted: Thu Apr 19, 2012 8:27 pm
by spadey99
Hi guys
bought a cbr 600rr set up off here and am fitting it at the weekend, one question is I have Pazzo levers,
A) will the Pazzo lever fit into the CBR brake lever housing?
B) can I disconnect the master cylinder from CBR reconnect to my original RVF one so keep RVF brake housing but swop mater cylinder, hoses and calipers???
Steve
Re: Fitting CBR 600rr caslipers and master cylinder, advice?
Posted: Thu Apr 19, 2012 8:30 pm
The levers will fit anyways...I reckon!
So, do A and not B
The master cylinder is the housing you are talking about...
Posted: Thu Apr 19, 2012 8:35 pm
by mo haggs
as cmsmj1 said the mastercylinder isthe leaver housing.
so in short - if the leaver dont fit, buy a different lever.
if you dont want to buy a different lever you will just have to run the rvf mastercylinder
Posted: Thu Apr 19, 2012 8:40 pm
by spadey99
Ok cheers guys, probably better off running a different lever and sticking with the CBR master cylinder as surely that will make a difference? Or is it mainly the calipers that make the difference.
Would like to keep the Pazzos but the most important part is to maximise braking.
Steve
Posted: Thu Apr 19, 2012 9:38 pm
it will fit fine and the master cylinder is a big part of getting it to work properly
Posted: Thu Apr 19, 2012 9:52 pm
by porndoguk
CMSMJ1 wrote:it will fit fine and the master cylinder is a big part of getting it to work properly
So many say, but nearly 2 years on, mine still are shit hot on the standard NC30 m/c, even kev at projex noted how sharp they are.
Posted: Thu Apr 19, 2012 10:11 pm
by spadey99
Hi Porndog
so are you running standard rvf m/c with CBR 600rr calipers???? Would prefer to leave master cylinder and just change hoses and calipers.........
Steve
Posted: Fri Apr 20, 2012 1:36 am
by amorti
RVF master cylinder is 14mm. RR master is 11/16" which is 17.5mm. That 3.5mm is a MASSIVE amount of area larger in this comparison.
So running RR calipers with the 14mm master is going to leave very long lever travel, I imagine. Very powerful, but long travel and probably squishy.
Stick with the original master or a 5/8" one if you find the lever too short travel or too on/off and want more gradation.
Posted: Fri Apr 20, 2012 7:52 am
by porndoguk
I can brake with one finger and on full squeeze theres about 1.5inch from the throttle.
Try it out, if its ok then shoot if not up grade
Posted: Fri Apr 20, 2012 8:06 pm
by spadey99
Thanks guys think I will just stick with the full CBR 600rr set up as it will make a massive difference I reckon.... Hey better brakes or cooler looking levers???? See ya levers.......
Steve
