Fitting CBR 600rr caslipers and master cylinder, advice???
spadey99
Post by spadey99 »
Hi guys
bought a cbr 600rr set up off here and am fitting it at the weekend, one question is I have Pazzo levers,
A) will the Pazzo lever fit into the CBR brake lever housing?
B) can I disconnect the master cylinder from CBR reconnect to my original RVF one so keep RVF brake housing but swop mater cylinder, hoses and calipers???
Steve
Re: Fitting CBR 600rr caslipers and master cylinder, advice?
The levers will fit anyways...I reckon!
So, do A and not B
The master cylinder is the housing you are talking about...
mo haggs
Bike owned: bikeless
Post by mo haggs »
as cmsmj1 said the mastercylinder isthe leaver housing.
so in short - if the leaver dont fit, buy a different lever.
if you dont want to buy a different lever you will just have to run the rvf mastercylinder
spadey99
Post by spadey99 »
Ok cheers guys, probably better off running a different lever and sticking with the CBR master cylinder as surely that will make a difference? Or is it mainly the calipers that make the difference.
Would like to keep the Pazzos but the most important part is to maximise braking.
Steve
it will fit fine and the master cylinder is a big part of getting it to work properly
porndoguk
Post by porndoguk »
CMSMJ1 wrote:it will fit fine and the master cylinder is a big part of getting it to work properly
So many say, but nearly 2 years on, mine still are shit hot on the standard NC30 m/c, even kev at projex noted how sharp they are.
spadey99
Post by spadey99 »
Hi Porndog
so are you running standard rvf m/c with CBR 600rr calipers???? Would prefer to leave master cylinder and just change hoses and calipers.........
Steve
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
RVF master cylinder is 14mm. RR master is 11/16" which is 17.5mm. That 3.5mm is a MASSIVE amount of area larger in this comparison.
So running RR calipers with the 14mm master is going to leave very long lever travel, I imagine. Very powerful, but long travel and probably squishy.
Stick with the original master or a 5/8" one if you find the lever too short travel or too on/off and want more gradation.
porndoguk
Post by porndoguk »
I can brake with one finger and on full squeeze theres about 1.5inch from the throttle.
Try it out, if its ok then shoot if not up grade
spadey99
Post by spadey99 »
Thanks guys think I will just stick with the full CBR 600rr set up as it will make a massive difference I reckon.... Hey better brakes or cooler looking levers???? See ya levers.......
Steve
