(complete novice) nc 30 slip on exhaust
- Bike owned: vfr nc30
Hi everyone
last year i bought a vfr that was in need of a little TLC. so far all the cracked fairing has been repaired, waiting for the paint to be finished, seats recovered and new exhaust bought.
i went for a slip on but the problem that i have is that im not sure where to cut the original to fit the new can.
any pictures/help much appreciated.
thanks in advance.
kevin
total beginer, be gentle!
thanks in advance.
kevin
- Bike owned: 1990 NC30
Re: (complete novice) nc 30 slip on exhaust
The general consensus is... don't. Pick up a pre-cut half system off eBay and use that. Keep your nice, uncut original system as the price is only ever gonna go up and you'll kick yourself later on.
thanks for the reply
had a look on ebay and cant see anything. the original can is in bad shape blowing all over the place. how is the pre cut fitted is it a weld job. sorry for the ignorance.
right, got you now.
yeah thats what i have.
even with the poor state of the original exhaust silencer do you think its worth saving?
Perhaps not. It would mean cutting the old one open, re-packing it and welding it back together again. If it's as knackered as you say then it might not be worth the hassle. What's the exterior like? Any grazes or dents?
where i thought it was blowing, ive now taken a closer look and it looks like the the hole is intentional. im guessing to drain out condensation, its at the lowest part of the can.
it also had some kind of heat resistant tape on it on the inside near the top of the can, which i presumed was covering a hole. ive taken that tape off now to find 2 rusty studs/rivets underneath, what are they?
There's definitely a drain hole on the underside of the exhaust, but I'm unsure of the other rivets you're talking about. Any chance you could post some pictures?
Not sure how to add pictures. I've tried copying and pasting in but that doesn't work.
ill have another go tomorrow.
