Quick action throttle? (QAT) GK76A
				Marsbar
Hey,
Just wondering has anybody changed there throttle tube for anything else to reduce the movement to full throttle? as standard has a fairly large turn to get to 100% open.
I know morris has been tinkering but not found a solution yet.
Rob
Rob
- thunderace
- Bike owned: R6, YZF600R
Re: Quick action throttle? (QAT) GK76A
I'd have thought any QAT that fits a standard clip-on would do the job.
				Marsbar
Universal ones wont be that good because you would have to move the switch gear and brake housing closer to the yokes,
Morris on here found this site for a mod to do to the existing unit. looks piss easy to do will give it a go
http://www.kawiforums.com/2005-2006-zx- ... d-pvc.html
- Variablevalves suck
I would not trust a DIY throttle.
You can be sure if it goes tits up it will be at the moment you try and shut the throttle when flat out at the end of a straight.
By the time you figure it out you will be on the grass with your buttocks clenched!
