VFR400 K type forks stanchions into RVF400?
- xivlia
- Bike owned: Ducati 749 D
Hi there, ive another question. is it possible to insert the stanchion of a late type NC30 fork and put it inside an NC35?
cheers.
cheers.
lukemillar
Re: VFR400 K type forks stanchions into RVF400?
I'm confused? NC35 use USD forks, while NC30 runs RWU! I highly doubt the parts I interchangeable. K type is also the early damping model fork not the later cartridge ones
- xivlia
i thought the stanchions where just a bare tube, i thought they would be interchangable. but i dont know, thats why im asiking. and k type are the late type..
they fit in different ways though don't they? USD forks have the bottoms screwed onto the stanchions..
....and K are the early type
- xivlia
why is my bike K reg and have the late type forks then
K type and K reg are not the same...
1989 bikes are K bikes..the 1990 are L and so on..
Nc30 fork stanchions are 41mm the nc35 are 55mm fork uppers i believe so quite a difference.
- ibby4585
- Bike owned: SP's
xivlia wrote:why is my bike K reg and have the late type forks then
Mate owning these bikes you just need to forget what numberplate it says and what it says on the v5 nine times out of ten there will be errors in the year and description.
Just write down the frame number on the headstock and the engine number and then google NC30 model info. All the details will be there for you.
JKL etc are Honda designations for each year, NOTHING to do with UK licence plates.
NC24:
RH = 1987
RJ = 1988
NC30
K model = 1989
L model = 1990 / 1991
N model = 1992.
NC24:
RH = 1987
RJ = 1988
NC30
K model = 1989
N model = 1992.
