Removal of haft from bottom yoke
chownsy
- Bike owned: KS125, ER5,VFR400 NC24
As per title, How do you remove the shaft out of the bottom yoke as im sending the yokes off with the frame for powder coating.
Re: Removal of haft from bottom yoke
you dont it will need masking.chownsy wrote:As per title, How do you remove the shaft out of the bottom yoke as im sending the yokes off with the frame for powder coating.
chownsy
ah thanks, Guess ill be sending my NC21 ones off instead then as i tried to push it out with the press and bent the thread
Lucky that the NC21 and NC24 bottom yokes i have are identical
Chrissy_J
- Bike owned: VFR400Z NC21
The steering shaft will have been welded into the bottom yoke. To remove it requires the removal of the weld- and it's rewelding afterwards... not something to consider with a refinished yoke.
Mask it off instead, as stated above.
