Dog link bearing removal
Posted: Sat Apr 07, 2012 4:32 pm
by Drunkn Munky
Anyone got any tips on removing the needle bearings in the RVF dog bone link? Do they sit up against a ridge inside that prevents you knocking them out?
Re: Dog link bearing removal
Posted: Sun Apr 08, 2012 10:30 am
by arsey30
Tony,
I have not removed them, but it looks like they sit up against a shoulder, as the service tool is an internally expanding puller with slide hammer attachment.
They pull out, not pushed or knocked out.
I have not tried it, but maybe an expanding Rawl Bolt and studding with a a heavy tube may work.
The picture just shows the idea, some bits I found in the shed to assemble for the picture, not something I have used.
Lock 2 nuts [0r weld 1] on the studding to turn it, and file 2 flats on the rawlbolt to grip it to stop it turning.
It will cost little to try, just need the correct diameter RAWL bolt, there are a few different types some split end, some with sprung wired loose fitting side cheeks pulled up with a threaded tapered cone.
Posted: Sun Apr 08, 2012 5:57 pm
by Drunkn Munky
Yeah i see what you mean now ive looked it up in the manual, are these tools not available to buy? i dont think my blue peter effort would stand up to much abuse :)
Posted: Sun Apr 08, 2012 6:11 pm
by Le_Blur
Perhaps I've missed something, but could you not use a blind bearing puller?
Posted: Sun Apr 08, 2012 6:22 pm
by arsey30
You should be able to make something that works, if not, then David Silver sells the puller,
Remover £30
Handle £6
Weight £59,
plus vat and carriage.
I expect there is standard pattern tool available a bit cheaper.
Posted: Mon Apr 09, 2012 1:09 am
by amorti
or - fit the rawl bolt, and expand.
Then, use a drift from the other side and a
BFH, and it'll come out? Can't see why you need a slide hammer type affair for this job, it's not a blind hole.
Or am I being thick?
Posted: Mon Apr 09, 2012 8:32 am
by arsey30
Yes, you are right, a drift is easier to find/make than a slide hammer.
Posted: Mon Apr 09, 2012 11:49 am
by Le_Blur
I made this at work one day from an old 10mm wheel axle I had knocking around. I needed a drift to get some cartridge bearings out of a hub.
Sorry about the quality of the photo. I just cut a slot down the length using a hacksaw, and then flared the ends out a little. It works by drawing the whole thing backwards through the centre of the bearing, and then the two halves spring out behind it and give a nice even contact with the bearing face for you to tap it out. I wonder if you could make something similar out of a suitable size of bolt or rod? Just a thought.
Posted: Mon Apr 09, 2012 6:15 pm
by Drunkn Munky
All sorted now cheers for all the replys, ended up giving it to timon to press out while he has a load of bits for blasting
