Track bike cutting out after 5 min
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
I got the bike running well yesterday. It took a complete carb rebuild but it is done. Now I am having a weird electrical problem.
The bike will start and idle fine, it even revs great. While letting it idle the bike just died. When it happened I noticed the temp gauge needle pinned to the right. I don't have the temp sensor hooked up, so I have no idea wtf is going on. When I try to start the bike, it acts as if there is no spark.
Any ideas?
thunderace
Bike owned: R6, YZF600R
Re: Track bike cutting out after 5 min
Post by thunderace »
It would be odd for both coil packs to be fcuking about so I would suggest maybe the CDI/ECU is to blame.
Bike owned: VFR400
Post by magg »
Can you connect the temp gauge sensor, if so and the gauge then reads ok then I suspect you might have a bad/no earth somewhere which is also affecting other things, like the ignition. The temp gauge might read full scale because it has power but the return to chassis is through some other electrical part and not direct to chassis.
An earthing fault innit?
Bike owned: VFR400
Post by magg »
My earlier response had a type, if you connect the temp sensor wire and the temp gauge STILL reads full scale then I would suspect an earth fault, for the reason stated above.
silver1956
Bike owned: Ducati 749S,BMW F800S,XBR500
Post by silver1956 »
It does sound like an earth problem, but if you had the carbies off then you had the tank off too ,so it could be a trapped fuel hose or vent hose.
Dave
thunderace
magg wrote:My earlier response had a type, if you connect the temp sensor wire and the temp gauge STILL reads full scale then I would suspect an earth fault, for the reason stated above.
If you'd said that in the first place, I wouldn't have suggested the CDI. You made me look silly :P
vfrman
Post by vfrman »
I am leaning toward earth myself, unless it is overheating and somehow knows to shut down. Can't imagine how because like I said the temp sensor isn't even hooked up. It isn't a blocked fuel line because I was running the bike off of a gravity bottle and not the fuel tank.
thunderace
BTW, the temp gauge will max out if the sensor is disconnected, it's part of the fail-safe design :peace: If you're not running with it connected, you need to short out the connection block.
vfrman
Post by vfrman »
Good info. I plan on connecting it....the harness I have is like a two or three prong (can't remember) and the sensor is only one prong.
