compatable stators
compatable stators
well guys the stator cover (may be internals as well)on my 4he engine is knacked.
i,m eyeing one from a 98 fzs600, anyone konw if it will fit or how about the one from the 3tj engine will that fit
anyone used one from anyother model
thanks
thanks
- thunderace
- Bike owned: R6, YZF600R
Re: compatable stators
Thundercat
You mean a 4JH or a 3HE ???
The 4JH has the stator in the cover but the wires are in a different place to the 3TJ
The 3HE is just a cover with the stator on the end of the crank They look like the 1WG covers.
I might have one for a 4JH but not sure - I've got a 4JH engine but not sure if it has a stator on it or not.
- thunderace
Evilchicken0 wrote:You mean a 4JH or a 3HE ???
Well spotted, I missed that
sorry guys its a 4jh engine.
i think ive got a 600one. ill take a pic. if it isnt id be i.terested to see what it is off!
so thunderace is the cat engine
the same as the 4jh then cause if it is that would make the fazer engine upto 2003 a potential doner.
correct me if i'm wrong ,didn't the 98-2003 fazers get the cat engine.
- thunderace
The Cat engine is basically the 4JH tweaked a bit. The only differences are in fuelling & BHP (true RAM Air system on the Cat) and sprocket offset (front sprocket sits further out compared to the FZR, due to a slightly different gearbox) .
The Fazer engines are slightly different too the cams were revised slightly and it has false fins on the barrel / head. The stator should fit though.
One thing get the stator and the cover as one, the bolts are difficult to get out, and the soft machine screws are locktitghted in
- Kayla850
- Bike owned: Sunn Tzar S2
I've got a clean spare cover and stator from a 4JH engine if you still need one
www.projection-racing.com
www.pjcfasteners.com
