General Question re: Oil filter...
vr46
- Bike owned: All sorts
Hi,
Quick query, when my mate changes his oil & filter he always pours new oil into the filter before fitting it. Why would this be necessary?
Ta,
Jeff
Ta,
Jeff
Re: General Question re: Oil filter...
Just so that there is no pressure drop when running the motor - if it is already filled than you are sorted, It is good practice
- thunderace
- Bike owned: R6, YZF600R
So much easier to fill to the correct level. If you don't and rely on the window or dipstick, once you've got the bike running, the oil circulates and fills the filter. when you switch off and it settles, the oil level on the window/dipstick will have dropped quite significantly.
In most cases, the filter capacity is more than the difference between MIN and MAX on the window/dipstick.
vr46
Ah I see, thanks for that
I don't recollect it being written in the workshop manual which I always follow for correct oil capacity etc.
I always follow the OEM sticker on the engine case as well as the manual - 3 different oil levels are inidicated. One of the quoted oil levels cater specifically for a new filter...
yeurman
if you fill the oil filter, how do you stop all the oil spilling out when you turn it on its side to it screw in????
Col
Col
- thunderace
yeurman wrote:if you fill the oil filter, how do you stop all the oil spilling out when you turn it on its side to it screw in????
Col
Magic
- jetblack
- Bike owned: '89 NC30 SEED
thunderace wrote:yeurman wrote:if you fill the oil filter, how do you stop all the oil spilling out when you turn it on its side to it screw in????
Col
Magic
Cunning and speed
gullarm
After an oil and filter change I just crank the engine with the ignition off until the oil light goes off (and a few more secs for good measure).
I saw this oil fill technique on the tv program ' a car/bike/4x4/helicopter/mg is born' and must admit it can't do any harm, as long as you don't spill oil all over your drive/fairings/hand/arms etc.
