de restriction kits?
frenchie
- Bike owned: nc30,nc24,s and a scabby kwak
just need to know where i can get de res kit for a 1990 gsxr 400 rsp?? thanks
- Variablevalves suck
Re: de restriction kits?
What do you mean when you say derestriction? do you mean the speed restriction at 180KPH?
frenchie
Sorry,forgot,yes the 180kph res.....thanks
Its a DIY.
Find the green/yellow wire that goes from the gear sensor (near the front sprocket) up to the cdi.
Under the seat it has a bullet connector.
Disconnect this, leave the gear sensor side loose.
Connect a 1k ohm or 1.5k ohm resistor to the cdi side end and then connect the other side of the resistor to earth on the frame.
You have no restriction at 180kph.
Jaicen
- Bike owned: GK76SP & ER6F
Does this affect the retard/advance at high revs for the SP models though?
Im unsure but thats all the Mmax boxes do.
If you take ohm readings for each gear you could run any of the resistances from the lower gears tho i dont think the cdi's are that clever, you dont get multi curves!
Only way to test would be dyno each resistance and see if any change in power.
ben2306
- Bike owned: gk76a
does this work for 93 gk76a?Variablevalves suck wrote:Its a DIY.
Works for all suzi 4's.
