Thread pitch?
- mo haggs
- Bike owned: bikeless
Thread pitch?
Can anyone tell me the size/pitch of an nc engine bolt?
- Bike owned: 1990 NC30
Re: Thread pitch?
The two on the right are M10 x 40mm. The left front is the same but the left rear is M10 x 50mm. I can't remember if they're fine pitch or not.
http://www.cmsnl.com/honda-vfr400r3-199 ... _2800.html
- mo haggs
Re: Thread pitch?
Its the pitch im really after ie. m10 - 1.2 or 1.1 or 1.5ect
Thanx for the reply though
Re: Thread pitch?
I'll whip one out tomorrow and find out for you. Unless somebody happens to answer before that.
- mo haggs
Re: Thread pitch?
Legend
Re: Thread pitch?
threads metric common pitch is 1.25
- thunderace
- Bike owned: R6, YZF600R
Re: Thread pitch?
twist&go wrote:threads metric common pitch is 1.25
But you'll find that the Japs don't think like that. Some bolts may be 1.25mm pitch but others may be 1mm pitch.
Re: Thread pitch?
The engine bolts and subframe bolts are 1.25 pitch fine pitch, m10 normally are 1.5mm corse pitch.
Hope that helps mo.
Rick
Hope that helps mo.
Rick
Re: Thread pitch?
The head bolts will be course for ease of fitting,1.5mm.
Re: Thread pitch?
The Honda Common service manual is useful it has all of the pitches for different types of bolts they use on bikes.. obviously there are some exceptions and these are docuemented too.thunderace wrote:twist&go wrote:threads metric common pitch is 1.25
Might not give you the exact answers for everything but worth having if you don't already have
