1992 nc29 wont rev past 5,000 rpm when riding
swdesigns
Post by swdesigns » Tue Mar 13, 2012 8:43 pm
Finally got my bike on the road but it struggles go rev cleanly past 5,500 rpm and upwards. It does feel like low fuel even with a full tank, or a flat spot where you hit a wall in the rev range but up to that point it pulls strongly and clean and runs very nice. it will rev cleanly in netrual past 8,000rpm and when on the paddock stand in gear it will rev cleanly all the way through to 9 - 10,000 rpm etc. The Carburation has been balanced to spec and sounds very strong on the throttle. very crisp.
I brought a set of good second hand clocks off a dealer, the speedo has had the speed restrictor taken off, but the dealer has said it won't effect the bike also it's got a mircon race end can but apart from that everything is standard spec. Has anyone else had this problame ?
vr46
Bike owned: All sorts
Re: 1992 nc29 wont rev past 5,000 rpm when riding
Post by vr46 » Tue Mar 13, 2012 9:00 pm
I've had this problem and it was directly related to a duff set of clocks! (speedo wire)
Luckily I had a spare clockset and once plugged in it immediately solved the RPM restriction.
The same problem is mentioned here:
viewtopic.php?f=28&t=31898
swdesigns
Post by swdesigns » Tue Mar 13, 2012 9:57 pm
Thanks for your replay is there anyway of fixing the clocks or do you have to replace them
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
Post by dunkenb » Tue Mar 13, 2012 11:36 pm
Its probably the speedo restriction not working properly( if you just disconnect it , it shuts down two cylinders) Doing the cdi wire splice to remove the restriction completely should get round this. 8-)
swdesigns
Post by swdesigns » Fri Mar 16, 2012 8:52 pm
Cheers guys have fixed it now it was down to the resiscter in the locks
