K fork springs orientation?
- Bike owned: 1990 NC30
When I removed them I found the fork springs have the closer wound coils at the bottom, howveer reading the Haynes manual on the installation section it states "install the spring with its closer spaced coils at the top"
So did the previous owner fit the springs the wrong way up, or is Haynes wrong?
- thunderace
- Bike owned: R6, YZF600R
Re: K fork springs orientation?
Tighter helix at the top of the forks
Thanks, that means the previous owner had them in the wrong way round! I even sketched the arrangement as I took it apart to be certain I put them back the same way too, I hope it won't have damaged them.thunderace wrote:Tighter helix at the top of the forks
- thunderace
Shouldn't have damaged them, it would have just fcuked up the handling under heavy breaking.
- Bike owned: ftr223 650 bros
Look closely at each end of the spring, then down inside the stanchion where the spring seats on the damper body.
If one end of the spring is tapered, i.e is a smaller diameter, then that faces down and sits neatly on the damper body. [normally the close coils]
The smaller I.D goes to the bottom on L model and 750.
Only if the spring has no taper, then close coils to the top.
You will do no damage if both ends of the spring are the same diameter, if not, the larger end will not sit well on the damper.
- thunderace
The tighter helix ALWAYS sits at the top on RWU forks, they only fit the opposite way on USD forks.arsey30 wrote: If one end of the spring is tapered, i.e is a smaller diameter, then that faces down and sits neatly on the damper body. [normally the close coils]
Not if 1 end is tapered, see common service manual.
vfr570 is tapered on close coil end
The springs are not tapered, either end seems to sit OK on the damper, so I assume its close coils to the top
arsey30 wrote:Not if 1 end is tapered, see common service manual.
Yes and yes.oldgreyandslow wrote:The springs are not tapered, either end seems to sit OK on the damper, so I assume its close coils to the top
That's right.
Not sure if they compress any different progression wise either way up, but best for unsprung weight.
Just like the Clubman Bantam rear shocks :-)
