1991 bandit variable valve
				chaslam07
hi, i am looking at buying a 1991 variable valve engine for my gsxr 400, i just want to know if anybody knows what else i will need to get it working, loom, starter motor, cdi ? thanks
						- thunderace
- Bike owned: R6, YZF600R
Re: 1991 bandit variable valve
Loom, starter, CDI, carbs, coils & HT leads.
						- Variablevalves suck
Ive told you it will not work. All the fittings on the loom are in a different place so you wont be able to connect the clocks or switch gear, you will need the VVT relay (expensive) its got more fuses so fuse housing etc etc.
