Starting Problem
				GixxerRC
Starting Problem
Gsxr-400 '94 (GK76a)
It's been off road since 01/01/2002. I brought this bike 2012 and it was a runner baring in mind it's done 4 miles in 10 years ( MOT road test ) I picked it up after having restrictors fitted/MOT/Service etc. got it home and it won't start, the garage had left it in 'Prime' when they set up carbs etc.. so I checked:
Spark plugs:
Black as hell so fitted new ones. Got spark (how strong should the spark look though)
Air filter:
Was full of nuts!! I'm guessing squirrels used it for food storage. New one on order. But in general looked ok
Serviced my arse!!
Battery:
Brand new and %100 charged and on trickle charge
Starter motor:
Jolts bike when in gear and clutch out so that's fine
Fuses:
All new under seat
Anymore anywhere else?
Fuel:
Drained fuel out of carbs
Drained fuel out of tank (off bike)
Added 5l fresh fuel
Carbs have got fuel going to them
Bikes not backfiring
Any ideas?
On my list:
Check if fuel is getting to cylinders
Take off carbs and clean them
Fit new O'rings
Check ignition system with multimeter (how/what to check would be brilliant thanks)
Thank you,
Ricky
( I would search but I'm on phone which makes it very awkward sorry )
Spark plugs:
Air filter:
Serviced my arse!!
Battery:
Starter motor:
Fuses:
All new under seat
Fuel:
Added 5l fresh fuel
Any ideas?
On my list:
Fit new O'rings
Thank you,
Ricky
- Variablevalves suck
Re: Starting Problem
First i would check and clean all the electrical connections, spark should be nice and blue (not yellow).
Rebuild the carbs with new o'rings and fit new plugs.
				GixxerRC
Starting Problem
This is what came out the air filter...
				GixxerRC
Starting Problem
Unless battery is straight off charge the spark is a bit faint.
New plugs fitted today
And I'll fit o'rings this weekend :) and clean carbs. What's the best way to clean my carbs?
				GixxerRC
Starting Problem
How do I check if i'm getting fuel past the carbs and into cylinder? Because surely it would backfire if I've got fuel/spark?
Also should be checking compression tomorrow.
Getting nice blue spark :)
I've got some feeler gauges and will check valve clearance.
Will I need a new rocker gasket once I remove cover???
One spark plug was covered in oil??
If you are getting fuel but not running you should find that the plugs are wet.
If its stood i would be giving them carbs a good clean.
				GixxerRC
Will clean ASAP :)) o'rings on way? :)
But what is causing the oil? It's not thick. If I blow on it, it just flies off.
- thunderace
- Bike owned: R6, YZF600R
GixxerRC wrote:This is what came out the air filter...
				GixxerRC
Starting Problem
I've changed O'rings but still not working. So I checked spark again and realised one spark is a lot stronger than the rest and the other three have a slight yellow spark within the blue??
