SP carb question
royster81
SP carb question
Post by royster81 »
I think I'm right in saying the SP gsxrs came with different carbs to the normal gsxrs ?
If so whats the difference?
Can I put normal carbs on the SP bike ?
Marsbar
Re: SP carb question
Post by Marsbar »
viewtopic.php?f=53&t=33537
SP carbs have a TPS sensor and pressurized floats. Has more tubes.
royster81
Post by royster81 »
Solid advice mate cheers, do they have an id number stamped on them too, I heard someone say there were different sizes of carb ie 32 mm and 34mm, which are SP and which are normal or are they the same.
Jaicen
Bike owned: GK76SP & ER6F
Post by Jaicen »
The SP carbs are bigger (35 or 36mm can't remember) so the manifold and/or airbox might need changing.
They also have a TPS, so using non SP carbs would probably require you to switch to the non-SP CDI.
To be honest, i'd look at swapping to a less problematic carb system altogether if you're looking for a change.
Marsbar
Post by Marsbar »
You can use the standard non TPS carbs on the SP cdi, had mine running for 200 miles. ill be getting some SP carbs when i can afford them, guy on e-bay is selling one for £200, sonic cleaned and re ringed.
Variablevalves suck
Post by Variablevalves suck »
They are 35mm, why you thinking of swopping them?
royster81
Post by royster81 »
When the owner got the bike he was given a set of spare carbs with it and was told they needed swapped for the ones in the bike as they had a crack in them which was currently covered in chemical metal.
I don't know much about gsxr's but I did know the SP had different carbs so to save some head scratching I thought I'd make sure we had two sets of SP carbs.
Thanks for the help so far lads.
Variablevalves suck
If the carbs are all sp ask if i can buy the old set for spares.
Chris.
VFRkieran
Post by VFRkieran »
Are there any other diffrences internally with the SP carbs? Im sure i have a set on mine and i need to know if there are any diffrences when replacing the orings etc.
