Where to go, What to do next, HRC carbs??
Posted: Fri Mar 02, 2012 2:49 pm
So, ive kinda finished my trackbike, to the extent that its up and running and working as it should be, But now im a bit bored and wanna keep going, but looking for a bit of a direction of what to look at next.
I'm currently running a stock induction set up, with the filter (OEM honda) airbox with full snorkel and airbox base including the tray thing that goes into the v of the frame which is all intact and un cut, has no holes cut into it. I have not drilled my slides but i also haven't checked to see if a previous owner has but either way pick up does not seem to be wanting.
I do not have the rubber flap (Part 15 in the link below) on the bike though, this is because the bike came without the rubber flap.
C:\Documents and Settings\hodgsonk\My Documents\NC30 docs\rubber flap.mht
I am running a full micron system, and have 120 jets in the front and 122.5 in the rear, after a trackday at oulton on the 18th Feb i had a look at the plugs and the back plugs seem spot on and the front plugs maybe a little lean, but not very much, touch and go really as to whether its worth changing them, bike felt fit and healthy right through the rev range didnt feel to lag or bog anywhere.
I have got a rs250 shock resprung and set up for the NC30, forks are modified and feel good, brakes were all split, fully serviced with seals and fluids, fresh pads.
I dont wanna spend a stupid amount of money so the engine is staying stock, its been ported prior to me buying it and thats how its staying.
Im thinking HRC carbs, im right in thinking that i just need the stacks that are now available from RO, plus some bigger main jets and 40 pilot jets. Mod my carb mounting tray to remove the ridges and and drill the holes, anything else? NC24 slides would be good but not sure they are strictly 100% necessary? i know your meant to buy needles too but i have weird adjustable needles in the carbs that came with it, you can see them here, first post on page three.....
viewtopic.php?f=24&t=28092&start=20
Anybody got any advice of what to look at next, or do we think HRC icarbs is the next logical step. Or just ride it till i enter a race and then see how much it s lacking?? or Dyno it and see what we got to start with? need to know a good guy in the northwest that knows his V4's mind, any ideas?
Bike is purely going to be a trackbike so open carbs not a problem although i thinking i'll put some wire gauze over them all the same.
Any ideas or guidance appreciated.
