NC30/35 front wheel bearings?
lukemillar
Hey,
Can anyone confirm in NC30/35 front wheel bearings are the same part numbers? I have come up with a couple of different ones and am unsure which is correct or if it makes no difference
Luke
Luke
marcus57
Re: NC30/35 front wheel bearings?
As far as I'm aware the only differences between the two on the front wheel is the spindle and spacers , sure bearings are the same .
Same numbers - same wheels
lukemillar
Cheers! Not sure why there are so many part numbers floating about for these - different suppliers maybe?CMSMJ1 wrote:Same numbers - same wheels
there are set codes for the bearings - 6004 RS off the top of my head. RS is the shielding/sealing code, the numbers the size.
