Nc24 help needed petrol leak
Tech2
Hi I've got a nc24 with a petrol leak from the carb it's where the choke pulls a pin out on the right back had a quick look but don't really know what I iam doing. It all looks ok to me do could really do with some help please
- Bike owned: VFR400
Re: Nc24 help needed petrol leak
Not an NC24 owner but would like to help. When you say a leak, is petrol running or dripping out or just wet? Is it worse when you pull on the choke?
Tech2
It is weeping but left over weekend and it must have drained the carb as a big pool on the floor same if choke on or of at the moment I've got tap to the off position and drained carb so it's dry at the moment
Does the NC24 have vacuum operated fuel tap?
Tech2
Yes I think so
So with tap in ON position there is an immediate leak of petrol, same applies with engine running and you can see the wet area on the carby with the tank in place, I ask because on an NC30 you cannot see any of the engine with tank and seat in place.
Tech2
Yes if bike off I think only leaking from what is in the carb if runing a constant leak. On the nc 24 you can see a small part of engin/carb with tank in place
Assuming the leak is from the choke plunger pin, I would suspect the seal in the plunger retaining nut is faulty. If the plunger pin is visible then perhaps you can remove the retaining nut and check the seal.
However I would not have expected much petrol would leak from this point even with a faulty seal. For a large leak I would suspect a split petrol hose to that particular carby or a leaky joint at the petrol inlet point for that carby.
I know I have offered up lots of possibilities, hope it helps to locate your the problem.
Tech2
Thanks I will have a strip down and have a look hope it is something like that nice and simple
