Page 1 of 3
advice needed (NC 30/35 loom differences)
Posted: Tue Feb 07, 2012 11:07 pm
by mo haggs
ok so i have lay my 35 loom out on the floor and i have conected all of the connectors to the relevant hardware.
everything seems to be in order, apart from the rad fan connector and the start/kill switch connector.
i know the switchgear are not interchangeable between the 30/35
so i know that i have the wrong switchgear unit (loom has 7 wire connector my switch has 5).
i can't find a connector for the rad fan on the loom
but even then - the connector on the fan has 3wires where the wiring diagram shows 2,
so i now have the wrong lower rad to.
so i guess what im asking is - where is the rad fan connector on the 35 loom?
and would anyone like to swap an nc35 start/kill switch and lower rad for the nc30 units that i have?
Posted: Wed Feb 08, 2012 7:28 am
by hannakournikova
Mo I'm nearly sure I have an old nc30 loom you can bastardise for bits if you need.
Re: advice needed (NC 30/35 loom differences)
Posted: Wed Feb 08, 2012 6:39 pm
by mo haggs
are you going to the kings hall show this weekend?
Posted: Wed Feb 08, 2012 7:20 pm
by hannakournikova
Frig didnt even know it was on. Not sure, Missus is working sat and sun tho. hmmmmmm
Posted: Wed Feb 08, 2012 10:16 pm
by skinnydog0_0
Are you using the 35 loom on a 30 engine Mo?
Posted: Wed Feb 08, 2012 10:54 pm
by mo haggs
skinnydog0_0 wrote:Are you using the 35 loom on a 30 engine Mo?
Yeah, but the starter switch is from a 30 and has two less wires.
I'm struggling two see what to do with said wires.
Idealy i would like to change it for the correct switch if i can find one.
As for the radfan, it may be junked in favor of an oil cooler
Posted: Wed Feb 08, 2012 10:56 pm
by mo haggs
hannakournikova wrote:Frig didnt even know it was on. Not sure, Missus is working sat and sun tho. hmmmmmm
I'm going on sat and could meet you there for a bit of a yarn,
i should know by then wether i'm going to start cutting looms up or not
Posted: Wed Feb 08, 2012 11:06 pm
by Drunkn Munky
Just had a look at both wiring diagrams and i dont think its possible to alter it for the 35 loom without bodging it, i think i have a 35 starter switch, i'll do a swap if the 30 one you have is in good condition, ie not faded.
Posted: Wed Feb 08, 2012 11:16 pm
by mo haggs
Drunkn Munky wrote:Just had a look at both wiring diagrams and i dont think its possible to alter it for the 35 loom without bodging it, i think i have a 35 starter switch, i'll do a swap if the 30 one you have is in good condition, ie not faded.
Its good nick with no fading, it does however have a srape above the start lettering.
I'll send you a pic via mobile now
Posted: Wed Feb 08, 2012 11:28 pm
by Drunkn Munky
Thats ok it sounds fine i cant work out how to recieve pic messages anyway
Do you have the left nc30 switchgear? ive got a good 35 one to swap also if you have
