advice needed (NC 30/35 loom differences)
- mo haggs
- Bike owned: bikeless
ok so i have lay my 35 loom out on the floor and i have conected all of the connectors to the relevant hardware.
everything seems to be in order, apart from the rad fan connector and the start/kill switch connector.
i know the switchgear are not interchangeable between the 30/35
so i know that i have the wrong switchgear unit (loom has 7 wire connector my switch has 5).
i can't find a connector for the rad fan on the loom
but even then - the connector on the fan has 3wires where the wiring diagram shows 2,
so i now have the wrong lower rad to.
so i guess what im asking is - where is the rad fan connector on the 35 loom?
and would anyone like to swap an nc35 start/kill switch and lower rad for the nc30 units that i have?
- hannakournikova
Mo I'm nearly sure I have an old nc30 loom you can bastardise for bits if you need.
- mo haggs
Re: advice needed (NC 30/35 loom differences)
are you going to the kings hall show this weekend?
- hannakournikova
Frig didnt even know it was on. Not sure, Missus is working sat and sun tho. hmmmmmm
- skinnydog0_0
- Bike owned: Penny Farthing
Are you using the 35 loom on a 30 engine Mo?
- mo haggs
Yeah, but the starter switch is from a 30 and has two less wires.skinnydog0_0 wrote:Are you using the 35 loom on a 30 engine Mo?
I'm struggling two see what to do with said wires.
Idealy i would like to change it for the correct switch if i can find one.
As for the radfan, it may be junked in favor of an oil cooler
- mo haggs
I'm going on sat and could meet you there for a bit of a yarn,hannakournikova wrote:Frig didnt even know it was on. Not sure, Missus is working sat and sun tho. hmmmmmm
i should know by then wether i'm going to start cutting looms up or not
Just had a look at both wiring diagrams and i dont think its possible to alter it for the 35 loom without bodging it, i think i have a 35 starter switch, i'll do a swap if the 30 one you have is in good condition, ie not faded.
- mo haggs
Its good nick with no fading, it does however have a srape above the start lettering.Drunkn Munky wrote:Just had a look at both wiring diagrams and i dont think its possible to alter it for the 35 loom without bodging it, i think i have a 35 starter switch, i'll do a swap if the 30 one you have is in good condition, ie not faded.
I'll send you a pic via mobile now
Thats ok it sounds fine i cant work out how to recieve pic messages anyway
Do you have the left nc30 switchgear? ive got a good 35 one to swap also if you have
