How do I remove the quitening gears ?
marcus57
As above ( excuse my spelling )
Never done anything with an engine apart from replacing a clutch and I don't want to end up with a pile of bits .
Is it something I can do myself with some time and a Haynes ?
- Jamboy
- Bike owned: 916 ,NC30, CBR600RR, RGV250M
Re: How do I remove the quitening gears ?
They have to be cut off mate, sounds good done I think but others will think it sounds like a bag of spanners runnnig.
It also gets rid of that dreadful wineing noise they make
Living Life, Living The Dream
marcus57
It's for my track bike so I'm not overly fussed about the noise , hoping someone can give me a how to .
- Jamboy
In fact you've given me an idea now while it's in bits having carbs and things done.
Was going to wait till mine was having the heads ported but thats on the back burner till I have more time to get involved.
- Jamboy
Just spoke to my brother and he said it's cams out, unbolt the cam drives and whip them out cut off carefully with a grinder place back in and time the cams back up job donemarcus57 wrote:It's for my track bike so I'm not overly fussed about the noise , hoping someone can give me a how to .
Doesnt the head or something need skimming to take up the slack it leaves? probably wrong but im sure ive read that something needs doing along them lines. It does sound great tho although i wouldnt do it to a stock bike.
- Jamboy
If I'm right you shim up only if the heads have been skimmed.
- Jamboy
Found this link if it helps and Simon Edgely (edge65) can help if anymore help needed
viewtopic.php?f=24&t=6808
With youtube link of Simon's RVF running
reverse cylinder jim
Its easy mate and no cutting required on the ones ive done.
Remove cams and the gears are only held in with a circlip. Once its been removed slide off the thinner gear along with the spring and locating dowels.
- Jamboy
What about the lower ones James???
