nc23 coil problem
sewelly1989
Bike owned: NC23
nc23 coil problem
Post by sewelly1989 »
hi,
im bit of a beginner to building a race bike sorry if it sounds silly or simple but any help would be greatful.
heres the problem , i fitted the race ignition from gf, it will run. but on 2 cylinders 1/4 but no spark on 2/3 ive put the multimeter on and found 12v getting to the coils n thats as far as ive got so i dont really no what to do any ideas please??
thanks
adam
petrolhead19
Bike owned: 2 x nc23's 1 x nc29
Re: nc23 coil problem
Post by petrolhead19 »
Hey adam, first things first, do you have them in the right plug?
From left to right of the coils it should be 1-4-3-2
So first coil goes to plug 1 and 4 second to plug 3 and 2.
Also make sure you have the wires going to the coils right, blue/yellow tracer from cdi to 3-2, Yellow/blue tracer from cdi to 1-4 and black/white from cdi to both coils, if i remember the black/white go on right connector and coloured ones go on left connector.
Another thing try taking the plugs out and see if you have a good spark, if not get some new plugs.
Hope this helps
Adam
sewelly1989
Bike owned: NC23
hi
thanks for the help,first off we installed the advanced ignition (engine casing and advanced cdi) i think its dynatech 2000 .. anyway we connected it all together then the start button wouldnt work so i put a direct wire from coils 2/3 to a positive on the battery then it fires n starts runs fine so i wired it into the ignition and it would run but then when i went to rev it it cut out and then found out it was only running on two cylinders so i checked the wires re-soldered them all re-read the instructions and got one of my mates to help me out cause hes familiar with racing but not with the cbr's but still no spark from coil 2/3.i will double check everything thats very much for your help anyway ill let you know how it goes... :smile:
thankyou
adam
tanuki
Post by tanuki »
Adam give Graeme a ring he's got great after care and will help you set it all up.
