advice on Scottoiler ? NC30
- xivlia
- Bike owned: Ducati 749 D
hi there, i would like to buy a scottoiler system for my bike as the chain does get rusty here up in the north of scotland due to heavy rain pretty much 25hours a daY! but i didnt know which scottoiler to buy? and where/how to install it. if someone could point me to the right direction, it would be very helpful. thanks.
- CRM
Re: advice on Scottoiler ? NC30
the basic one is fine i have one on my RVF
locate the resevior under the seat on the righ hand side with the rear elevated, vacuum from the obvious place between the fuel vacuum, and oil feed follows the rear brake hose and the drip bolts to the swingarm chain guard bolt.
set to 2 gives enough of a drip to oil the chain.
- royster81
Pictures please crm
- CRM
phil x
The standard one is fine,
I stopped fitting the feed pipe to the rear sprocket, it blocks easily, only lubes 1 side of the chain, needs pipe/tiewraps along the swingarm & snaggs when refitting the rear wheel (not a prob on the '30/5). Much better to fit the outlet behind the front sprocket.
Phil
Phil
- CRM
thats a really good idea that phil. you got any pics of yours and where its exiting ?
- xivlia
soo... scottoiler v system? is that the normal one? i see on ebay there are specific ones for each bike..i cant seem to find the nc30 version. so i still dont know.. perhaps a link?
scotjell
- Bike owned: VFR400 NC30x2
I'm about to put my brake line through the swingarm and I think I will lose the scottoiler through there and come out the bottom!!! Once done I will post some pics if you lioke that sort of thing
phil x
Re: Re: advice on Scottoiler ? NC30
I have a pic somewhere, I'll try & dig it outCRM wrote:thats a really good idea that phil. you got any pics of yours and where its exiting ?
Phil
phil x
Not on an NC30 but I'm sure it'd fit somehow just make sure that there is no less than 5mm or so sticking down otherwise the oil doesn't drip, it just runs along the chain slider.CRM wrote:thats a really good idea that phil. you got any pics of yours and where its exiting ?
BTW, don't laugh at my anti-corrosion policy
Phil
