Piston Ring compatability
can anyone tell me whether piston rings are compatible between the VFR400 (NC24), VFR400R (NC30) and RVF400 (NC35)?
Re: Piston Ring compatability
Part numbers for Piston Ring Set (Per Piston)scooble wrote:can anyone tell me whether piston rings are compatible between the VFR400 (NC24), VFR400R (NC30) and RVF400 (NC35)?
NC24: 13011MV4305. [originally 13011ML0000 ]
NC30: 13011MV4305. [originally 13011MR8000 ]
NC35: 13011MV4305
So I would say yes.
The original part numbers are different between the 24 / 30 but they have been replaced with the new part number which is the same for all models.
- skinnydog0_0
- Bike owned: Penny Farthing
Neo, you wouldn't happen to have a pic of the standard 24 rings would you?
I have a new set of 35 ones i am curious and woudl liek to compare them.
Should be able to dig one up, i'll have a look.skinnydog0_0 wrote:Neo, you wouldn't happen to have a pic of the standard 24 rings would you?
The new NC35 ones will fit the 24 though
