nc30 piston rings and valve seal repair bill
leerc
doubt this is a diy job i can tackle so has anyone got a idea of what cost im looking at
- CRM
Re: nc30 piston rings and valve seal repair bill
cheaper by a long way to replace the engine.
CRM wrote:cheaper by a long way to replace the engine.
edit: double post - keeps doing it today for some reason?
the HW to buy is super pricy - rings were 16 quid each form my lcoal shop... I gave up on the idea.
valve seals are cheap..
if it is blowing/low compression - then it is one or the other isn't it? If rings, then maybe a clean up of them and poss some good 2nd had might do you on a freshly honed block.
