dose redex work
john21z
dose redex work
Post by john21z »
hi dose redex work at cleaning carbs the lazy way. even if i drop it in via the air filter , to stop a stickey float bowl
Re: dose redex work
john21z wrote:hi dose redex work at cleaning carbs the lazy way. even if i drop it in via the air filter , to stop a stickey float bowl
not really
Strip / clean and reset the carbs.
Redex will help keep a fuel system clean, it won't clean a badly dirty system.
If you get the carbs off properly you can check and adjust and set everything in one go.
While they are off, do the vavle clearances too, bike will love you for it.
