Please Multi help: NC 30 track bike
baptiste nc30
- Bike owned: SC25 , Ducati SS 1000 DS, NC30
Hi everybody,
happy new year, all the best for 2012...
On Monday, i tried to contact Rick Olive about several electrical trouble.
"I’m restarting a trackbike NC 30 mounted with 916 front and I need your help for spare parts and advice.
Since she restarted, I’ve some electrical disease with cylinder misfire (right side mainly), thus I decided to check all wiring harness and follow your advice and control all charging system.
First of all, I took the speedometer off and I keep the nude limiter. Can you please confirm that the speedo restrictor would have 2kΩ resistor. I checked that and I have discontinuity between Bu/Or and Bl/Br wires. Do I need to buy you a derestriction resistor.
I don’t understand the electrical mod (2 * 2kΩ resistor on the limiter connector (Bu/Or and Bl/Br) and on the CDI connector (Bu/Or and Bl/w) Can you confirm this mod, the Bl/w wire goes to the ignition coils, is it right? Is it 1 loop or both loop on the wiring loom for a race bike mod?
When I stripped the heatshrink at the reg/rectifier, I found a burnt connector (all five pins). I checked the Alternator and seems ggod, but there is no countinuity between the 5 pins of the reg rectifier. I don’t mesure the correct and recommended values in the Haynes manual (∞ instead of 500Ω). Do you think that the rectifier is down or some not OEM parts (mine is without cooling fins) have different specs? Do you sell rectifiers with plug and pins? Why there is so much price differences (from 50 to 120€?)?
Finally,
How much do you sell a complete electric pack:
simple CDI
coils and HT leads
Rectifier (if necessary)
Derestrictor (if necessary)
Concerning my carbs setup, your HRC carbs kit is very interesting, but my actual pilot jet are 35 and my main jets are 115 front and 118 rear.
If I order your kit, what do I need to modify for intake part (air filter, velocity stacks, etc…)
How much is it for sending all that parts to France (close to Paris)."
Is anybody know how i can contact him????
Maybe you have information for me....
Let's go.
Cheers.
Baptiste
Finally,
simple CDI
coils and HT leads
Let's go.
Cheers.
Baptiste
