front suspension part name
- Bike owned: NC35
hi all,
i was trying to change my fork oil and fork seals today, i noticed on one of my damper rods there is a coiled loop holding a ball bearing. this is perished but i dont know what this is called or part number if anyone can help so i can order a new one it would be appreciated.
i did try looking in haynes but no luck in the diagrams.
thanks,
slowsport.
thanks,
slowsport.
- Bike owned: NC35
Re: front suspension part name
thanks for that i think the part i need is called label b? number 17? wierd name would of never of guessed that!Drunkn Munky wrote:This will help http://www.cmsnl.com/honda-vfr400r3-199 ... _0800.html
again thank you.
- Bike owned: NC35
i think i spoke too soon...
http://www.cmsnl.com/honda-rvf400rt-nc3 ... t/F08.html
looking at that diagram if you look at the damper rod the coiled spring is betwwen 31 and 5 but on the damper rod...
please please if anyone can help what name or part number that would be so i can get my pride and joy back on the road.
Ah sorry i posted a link to the NC30 setup. The part your looking at looks to be the complete rod assembly, if its not listed as a part on there then i very much doubt its available seperate, unless you can find someone with some damaged forks to strip parts from.
- Bike owned: NC35
had a bad feeling someone will say that. okay thanks for your help
- skinnydog0_0
- Bike owned: Penny Farthing
I think you mean the re-bound adjuster mechanism. It's a wire sprung-circlip that hold the ball bearing in a little slot/hole?
If this is the right part and you only need the sprung-circlip, you can probably get one the right size from a motor-facotrs or hardware store. if the the ballbearing that is not working in the slot (i.e. not the correct movement or no movement) you will need to get a new damper rod assembly.
Can you take a pic or give a little more info on what the issue is?
- Bike owned: ftr223 650 bros
The damper adjuster ball is held in the detent by a continuous spiral spring of very thin gauge steel.
They sometimes break or stretch when stripping the damper rod.
If this is the case, then form a U on each end of the spring and clip them together away from the ball seat area.
If the spring is of no use, the forks are still useable, but the click adjustment will be lot, instead the damping adjustment will be continously variable.
Set the good one to the required number of clicks, noting the number of turns.
Now set the faulty one to the same number of turns.
It may be possible to make a new spring using something like those in oil seal lips .
Cut it to length and join it as above.
- Bike owned: NC35
skinnydog and arsey you guys are dead on to what i need, i know my description was vague at best! lol
the mechanism and ball bearing is fine it is just the continuous spiral spring that is all out of shape and needs a replacement.
If it is out of shape, then cut out that part, stretch it and join it up again, I have done that in the past.
