FZR400 3tj ---- R6 Shock
petrolhead
Can someone tell me is this the right shock for the 3TJ -R6 shock conversion.
Also Is it the R6 shock top bolt that is used or is it the 400 one.
Re: FZR400 3tj ---- R6 Shock
Yup thats the right shock - not sure about the top bolt
hunter
I would emagine its the 3JT bolt,as it's a 3TJ Frame,You will also need an extention addapter for the bottom mount.
joolsmi16
Iam also looking for a rear shock upgrade, read some people using a thunderace and yzf750 shock haven't read if these are any good..
I think I heard the 750 shock is close to the 3TJ's but I couldn't say for certain. They'd probably need a rebuild though so if you factor that in they're going to cost roughly the same as the R6 and shock extension.
The R6 shock is pretty good standard unit and it's a known conversion
petrolhead
Yea the 750 is the same from what I can make out ,,,,"google''
Going to get the rrsp one rebuilt and see how it goes first but if not happy will try the R6 ,
The rrsp one might feel a bit better with a rebuild and set up again,
- thunderace
- Bike owned: R6, YZF600R
joolsmi16 wrote:Iam also looking for a rear shock upgrade, read some people using a thunderace and yzf750 shock haven't read if these are any good..
They are the same shock but the Ace has a heavier spring.
oollit
- Bike owned: FZR400RR 3TJ, RF900R
The R6 shock top mount bolt is 10mm, but the 3TJ bolt 12mm, so you need top-hat washers or mod the 3TJ top mount locating bracket.
