1989 k model vfr forks spring & oil replacement
spyrius
Bike owned: Cbr125,cbr250,hyo gt250, nc30
Post by spyrius »
Hi all,
Is it possible to replace springs and/ or oil from front forks without need to remove forks from yokes? I have fork seals in good conditionand dont want them to be ruined when dismantling fork tubes. So, is it possible to unscrew top bolt and withdraw spring? I want to replace it with wemoto hagon progressive spring. I think my springs are weaken and worn, as i have bought bike a month ago and noticed when riding that i am bottoming out and frontfeel is quite rough over little bumps on road.
I have done previously seal removal on cbr250, so still remeber how it was frustrating to drive in seals without proper tool.
Enough of my rant... So is it or not?
Thanks in advance
phil x
Bike owned: 2 x 650 Transalp's, '90 nc30
Re: 1989 k model vfr forks spring & oil replacement
Post by phil x »
The forks have an oil drain stud on the bottom rear of each leg.
Remove the caps, compress forks & fill with oil to 90mm from the top (still compressed) unless Hagon suggest a different level, release the forks, install spring & replace the fork caps. Simples!
Phil
lukemillar
Post by lukemillar »
You should replace the oil when changing the springs. Reusing old oil is, like the suspension guy I used in Sydney once said, is like re-using a prophylactic!
You don't have to separate the stanchion from the fork bottom, so your seals needn't be affected, but I would remove the forks and up-end to drain the oil, rather than unscrew the damping rod bolt.
phil x
Post by phil x »
lukemillar wrote:You should replace the oil when changing the springs. Reusing old oil is, like the suspension guy I used in Sydney once said, is like re-using a prophylactic!
There is an actual drain bolt too ;)
Phil
lukemillar
Haha - So there is! Never noticed that before; I stand corrected
I'd still take them out the yokes and drain them properly. Pump all the old shit out and get them flushed through.
Leave the seals..that is no worries.
New springs is the best thing I did to my K model forks,
Gixxerpilotdave
One Hit Wonder
Bike owned: cbr125, Gsxr600K7, VFR400NC30
Post by Gixxerpilotdave »
Im debating doing the springs in my forks, how did it go? is it worth it?
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 »
CMSMJ1 wrote:I'd still take them out the yokes and drain them properly. Pump all the old shit out and get them flushed through.
:plus:
If you have the time, i would get them out and do it properly. You may as well do it right and not have to worry about getting the forks out again in a year or two's time. I would also change the springs ;) and the seals if they haven't been done in a while. If you do do the seals, you can use the old seal as a protector and a piece of scaffold tube split down the middle (or another piece of steel pipe from teh builders merchant) as the tool to drive the new seals into place.
spyrius
Post by spyrius »
thanks for all reply's will let you know once done over weekend
