NC30 Crankcase Set
Bike owned: VFR400
NC30 Crankcase Set
Post by magg »
Anyone replaced only one half of a crankcase set, any known negatives that makes this a no go.
Re: NC30 Crankcase Set
I know a guy who had an NC21 break a chain and damage the bottom end, he replaced it with the bottom from a motor that had knackered bores.
Both the 21 and 30/35 use the NC13E engine so cases arn't too different.
They are machined as a set but the Honda quality is quite consistent.
Most people will probably say it shouldn't be done, I guess you'd need to try it and see if it fits close enough not to leak, everything line up ok.
No option of replacing both, or repairing the problem?
Bike owned: VFR400
Post by magg »
Considering a big bore version and do not want to disturb/experiment with the current running engine. If the idea does not work then no harm done.
scooble
Post by scooble »
I tried doing this with a KR1S and both the halves didn't line up (you could see daylight through the gaps).
They tend to be a matched set, but if they're not, then it may be possible to machine them to match up, but it's probably a whole lotta trouble
