change pads nc21
bullitt
Bike owned: vfr400 nc21
change pads nc21
Post by bullitt »
hi guys
is it easy to change pads on nc21
cheers
Re: change pads nc21
how longs a piece of string.
front or rear pads?
Depends on your personal skill.
If you can use an allen key and a spanner or wratchet then you should be able to do it with your eyes closed.
However, some people struggle with a spanner.
When replacing the pads make sure to clean all the piston you can see before pushing it back into the caliper and check the rubber seals... they sometimes need replacing.
