inlet manifold gasket
- Bike owned: sprint st 955 fzr400 genesis
been told my inlet manifold on my 87 genesis is probably leaking . its running ok at high revs but lumpy in lower range . so anyone know where i might find inlet manifold gasket ? thanks muchly for any help .....
Re: inlet manifold gasket
Do you mean the carb to engine manifolds ??? You'll be lucky to find them chances are they're discontinued. You might get lucky and find some 600 rubbers that will fit, but I can't say they're a match for your bike.
If however your looking for the rubber O rings on them then it's probably easier to measure the it and just get a generic one.
I've got some carb-engine rubbers from a 3en1 if they fit?
cheers guys , not had a look yet but sure will now , might have those rubbers off ya then taggy . will get back to you on that one . cheers muchly ......
if they dont there are currently 2 inlet rubbers on ebay off a 600 id imagine they are identical fairly cheap aswell :)
- Bike owned: MC22, 3TJ1
I have these available as replica parts. I have tried them on my 1WG and the fit is identical to a new genuine part. I placed a post in the Approved Traders section.
cheers
cheers
https://litetek.co
https://litetek.co
