wrong exhaust causing splutter?
leerc
Post by leerc » Thu Dec 08, 2011 11:49 pm
just discovered the scorpion exhaust isnt for my vfr 400 its from a cbr 600
im thinking its the cause of my hesitation when fully opening the throttle low down
opinions?
Cammo
Re: wrong exhaust causing splutter?
Post by Cammo » Fri Dec 09, 2011 12:22 am
I doubt it.
It's more likely that the pilot screws on your carbs haven't been adjusted properly to match the exhaust. This will cause the symptoms you describe. Balancing the carbs can also help.
You can tune the carbs to suit virtually any type of exhaust system, let alone different mufflers.
leerc
Post by leerc » Fri Dec 09, 2011 7:06 am
is tuning the carbs easy? or am i best sticking it in a garage
Cammo
Post by Cammo » Fri Dec 09, 2011 10:45 am
leerc wrote:is tuning the carbs easy? or am i best sticking it in a garage
It's not difficult, but it can take a fair whack of time first time around - labour/time is what the garage will mostly charge for.
You need to know what your pilot screw settings are currently set at. I think you can get a screwdriver in there to check with the carbs on the bike (I've never tried), but it's much easier with the carbs off the bike, that's where the time is.
If you do it yourself:
- Tighten the pilot screws until they're just nipped up (not too tight), write the result down on paper for each cylinder (to the nearest 1/4 turn) and post this up
- A good starting point would be to then open them 2.25 turns out (count each 1/4 turn you do)
- See if that performs any better and get back to us
It's fairly common for these to be not properly adjusted.
leerc
Post by leerc » Fri Dec 09, 2011 5:15 pm
hopefully ill be able to get in without removing them
if the winds died down ill get stuck in at the weekend
leerc
Post by leerc » Fri Dec 09, 2011 8:02 pm
is it a case of making sure all 4 are set the same or does each carb need fine tuning ?
Post by Neosophist » Sat Dec 10, 2011 3:29 am
leerc wrote:is it a case of making sure all 4 are set the same or does each carb need fine tuning ?
All the same is more than enough
iDemonix
Bike owned: '92 NC30
Post by iDemonix » Sat Dec 10, 2011 8:49 am
If you'd like to buy a special device called a CarbTune we're having a group buy in January ;)
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 » Sat Dec 10, 2011 12:02 pm
iDemonix wrote:If you'd like to buy a special device called a CarbTune we're having a group buy in January ;)
Carb tune also do a very very very very useful 90deg screwdriver, this tool alone will save you hours and hours, well worth the £50, and if you are going to work on your carbs (balance or tune them) over the winter each year it's well worth the money.
leerc
Post by leerc » Sat Dec 10, 2011 4:42 pm
can they be done with the carbs on with that90 degree screwdriver?
