t/cat starter gear/motor compatability
scooby4/6
can anyone shed any light on the different engines/model/yrs that are compatible with the t/cat engine rearding the above?
starter gears+clutch
starter motor
gear selector shaft
cheers
starter motor
gear selector shaft
cheers
- Hogdigerdy Dog
Re: t/cat starter gear/motor compatability
I think the T'cat motor is the Foxeye with slightly higher compression and a stronger crank to cope with it.
bullitt118
The T'cat is 62 × 49.6 mm bore x stroke with nikasil linersEvilchicken0 wrote:I think the T'cat motor is the Foxeye with slightly higher compression and a stronger crank to cope with it.
The Foxeye is 59.0 x 54.8 mm steel liners..
Foxeye starter gears etc should be the same..
hunter
Sorry,don't know where you got that information but it's wrong.bullitt118 wrote:The T'cat is 62 × 49.6 mm bore x stroke with nikasil linersEvilchicken0 wrote:I think the T'cat motor is the Foxeye with slightly higher compression and a stronger crank to cope with it.
FZR600 3HE 59.00 x 54.8 mm steel liners. comp 12.0;1
foxeye 4jh 62.00 x 49.6 mm. comp 12.01
Thundercat 62.00 x 49.6 mm. comp 12.0;1
I also believe the foxeye and thundercat are steel liners.
The thundercat has stronger rods.
But having siad all that i think the starter motors are compatable.
scooby4/6
thanks for the replies/info,got the starter gears+clutch now,just on with the selector shaft+motor.
will be speaking to my engine guru next week,so will ask him to confirm the above (for anyone else who might need to know)
