NC30 Chain cleaning.
Spoilt01
Bike owned: Current : VFR NC30
Post by Spoilt01 »
Hi Guys,
I would like to find out what I could use to clean of all the dirt and old wax on my chain before I re-lube it? I stay in SA so I might not have the same products easily available.
I do have a bio-degradable cleaner which is strong enough to strip grease (Blade). Other than that I can only think of a little engine cleaner but i'm worried it might remain on the chain and weaken the new lube added?
Any advise?
RegionX
Bike owned: VFR400 NC30
Re: NC30 Chain cleaning.
Post by RegionX »
Quite ridiculous that you go on to an international site and the first advice you get is from a fellow Capetonian ;) . I use paraffin, in fact it usually says kerosene which I think is the same thing. It is not abrasive enough to damage anything and I still find it will remove small amounts of rust. Being that it is fairly mild it takes a bit of scrubbing but I rather not risk weakening my chain with anything else.
Just realized you may be doing this with the chain still on? Could be a bit difficult with kerosene, I always take mine off.
Spoilt01
Post by Spoilt01 »
RegionX wrote:Quite ridiculous that you go on to an international site and the first advice you get is from a fellow Capetonian ;) . I use paraffin, in fact it usually says kerosene which I think is the same thing. It is not abrasive enough to damage anything and I still find it will remove small amounts of rust. Being that it is fairly mild it takes a bit of scrubbing but I rather not risk weakening my chain with anything else.
Haha indeed what are the chances hey, we might even have seen each other or said hi since I ride with and know most of the VFR owners in CT :mrgreen:
Yes it will be done with the chain on the bike. So im thinking I should get some, use a cloth and wipe off as much as I can get off and then re-wax.
Thanks for the help bud :smile:
Old paintbrush and some parrafin / kereosene. Brush it into all the chain and let it soak for a minute. Then get a rag and clean it up.
After it's dried go for a short ride to warm the chain up and then apply your choice of chain wax / lube etc
Spoilt01
Post by Spoilt01 »
Neosophist wrote:Old paintbrush and some parrafin / kereosene. Brush it into all the chain and let it soak for a minute. Then get a rag and clean it up.
Much appreciated chaps, will do the weekend :rocks:
bighug
RegionX
Post by RegionX »
I'm a new owner with a fixer upper, haven't even ridden her yet ;), maybe il see you around.
Spoilt01
Post by Spoilt01 »
RegionX wrote:I'm a new owner with a fixer upper, haven't even ridden her yet ;), maybe il see you around.
Awesome man, many happy Km's ahead. Yeah send me a shout when you ready to ride a bit could come join me and a couple of guys. :mrgreen:
Spoilt01
Post by Spoilt01 »
Thanx alot chaps! Worked the charm very chuffed. Would take pics and show but not sure of how to add or upload.
But thanks again for the help ;)
RegionX
Post by RegionX »
Spoilt01 wrote:Thanx alot chaps! Worked the charm very chuffed. Would take pics and show but not sure of how to add or upload.
photobucket.com for future reference.
