VFR750 rear wheel con
- Bike owned: VFR400 NC30x2
All I know there is somewhere on here regarding the conversion, the question I have is there a specific wheel I need and yes I know it's the 4 hole single sided one
- 28hodge
Re: VFR750 rear wheel con
viewtopic.php?f=24&t=29989&p=214040&hil ... el#p214040
try this i think the early type is the curvy spoke wheel if that makes sense 5 spoke type
This sort Item number: 110775653223 on fleabay
- 28hodge
I think so but bear in mind i do not have a vfr750 rear ive got a rvf400 rear so not 100% sure, to the best of my knowledge i would say so, this will need the rick o converted hud to allow you to fit it, there are 2 vfr rears once a 5" and ones 5.5" its the 5" you want off the earlier vfr750.
again this is to the best of my knowledge.
- 28hodge
viewtopic.php?f=22&t=21878&hilit=vfr750 ... conversion
try this 5 spoke curvy 5" so i guess that one is the right one.
- Bike owned: v4's
vfr rears = 90-93 8 spoke 5.5", 94-97 5 spoke 5", 98 - 2010 5 spoke 5.5"
being able to ride from point A to point B does not mean you have skills
The 5" isn't that much of an advantage? What are you doing the conversion for?
You can put a 160 on a 17" 4.5 rim if you have the RVF rear wheel
They are becoming a little scarce now and fetching top dollar for the RVF 17" now and this was just a cheaper alternative. Reason for doing it is tyre choice mainly as the 090's are still fetching good money too.
I don't know about cheaper alternative, becuase you will have to modify the hub, or get a hub unit of Rick Oliver I think £120 exchange.scotjell wrote:They are becoming a little scarce now and fetching top dollar for the RVF 17" now and this was just a cheaper alternative. Reason for doing it is tyre choice mainly as the 090's are still fetching good money too.
Yes but if I can pick up a wheel cheap enough. Bargain! Or else 17" are going for £200+
