rad hose positions hybrid
wedge
Post by wedge »
are the hoses for the rad in the same positsion if i fit a 600 motor???..just i was looking at the samco hoses for the 400 3tj???
hunter
Re: rad hose positions hybrid
Post by hunter »
What rad are you using,I'm using the 600 rad so i use the 600 hoses.
wedge
Post by wedge »
part of my Q really....should i use the 600 rad???...or will 400 do?
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
I used a 400 rad on mine and it was fine. They're pretty much the same size if you look at them side by side, except the 400 doesn't have the oil cooler pipes (unless you've got an SP or a 4DX). I blanked the oil cooler lines off on my 600 engine.
Some have been able to use the standard right side hose turned around, but that didn't work for me so I made up a hose using standard 3TJ stuff I had lying around and some 7/8" handlebar tube ;)
www.projection-racing.com
www.pjcfasteners.com
hunter
Post by hunter »
If you use the 600 rad you can use 600 hoses.like i did.
StreetFZR
Bike owned: 3TJ 4/6 TURBO Streetfighter.
Post by StreetFZR »
How did you guys mount the 600 rad to the 400 frame?? I found that the mount different at the top
hunter
Post by hunter »
Hi wedge,got sme pics for you,
This is how i mounted my 600 rad.
And this is what i used to make them,aluminium angle.
