Igniter fixed!
				chris_psmith
Igniter fixed!
Well after a frustrating search for a spark, just spent £2.96 on 40 capacitors, used a whole 4 of them in the igniter, put it on the bike - sparks (at the plugs   ).
Well chuffed, fixed for under £3
Chris
 ).Well chuffed, fixed for under £3
Chris
- CRM
Re: Igniter fixed!
Wow - respect to you. seriously - well done am pleased for you.
have some karma
							have some karma
						- Variablevalves suck
Re: Igniter fixed!
Its a well known fix for the Bandit4, just dont try it on the 76a SP box (12 pin) as the inside of the box is full of rubber that is non removeable.
				chris_psmith
Re: Igniter fixed!
This is a 76a box, full of brown glue which was a right pain to get off!
Now got a spare 36 capacitors!
Chris
Chris
Re: Igniter fixed!
Ye the standard box is simply glued but the SP (12 pin) is completely filled with a black hard foam that cannot be removed. People say the bike has felt loads sharper and pulled better top end once the old caps have been changed.
Good to hear you got it fixed.
