Braided lines...
Goinphaster
Braided lines...
HEL USA is not longer in bussiness so I am going to have custom break lines made. Can anyone tell me how long RVF400 brake lines are (Left, right, Back) from end of Banjo Fittings? Going to use Spiegler to custom make them, just need the specs.
- RVFHooligan
Re: Braided lines...
I can tell you the measurements I used for the front (2 line, no T-fitting), 25 in. and 30 in. You will need a 2 line banjo for the top off the master cylinder. The rear line was 42 inch. I used Goodridge lines, Banjo, and fittings. RVF400.
