Boken drill in bolt!!!
scotjell
Regular Member
Bike owned: VFR400 NC30x2
Post by scotjell »
Hi all I know this isn't my NC30 but my little polo and unfortunately sheared off a bolt in the process off drilling out as the drill broke through snapped!! Does anyone know of a good company in the Bristol area for spark/EDM erosion to remove it. Oh forgot to mention its in the gearbox which is off the car as was in the process of doing the clutch!
Username
Bike owned: VFR400RK, VFR750FK, VFR750FH,
Re: Boken drill in bolt!!!
Post by Username »
I use a company in Hampshire when it's required. It's not cheap but they are mustard. Last time I used them they took a bolt out, with a snapped off easy out that had been inserted off centre, without even damaging the threads. Bit off a trek from Brisol though.
djcouch
Post by djcouch »
You tit Scott. That's why your office based !!
scotjell
Regular Member
Post by scotjell »
Well at least I'm not ginger! How's things anyway in miserable Plymouth I did see you on your bike, still going then!
NZgatch
Post by NZgatch »
Another way to get it out it to use a die grinder with a diamond tip, to grind out a center. Then use a 3 or 4mm carbide drill in a regular drill press. It has to be going FAST however. Like as fast as the average drill press goes. Carbide will smoke through any hss drill.
Then in there with your favorite kind of broken fastener removal tool.
I've removed dozens of broken cap screws and bolts like this.
djcouch
Post by djcouch »
The bike is now off the road for a refit. But was running ok.
Still miserable down here, same shit different dock!!
