Page 1 of 2
				Billet aluminium bottom yokes for 3TJ
				Posted: Mon Oct 10, 2011 1:22 pm
				by Kayla850
				I'm gauging interest for a batch of 3TJ billet aluminium bottom yokes to replace the awful standard cast steel effort. It'll be aimed at race/track bikes but there's no reason why they couldn't be used on a road bike, loads of newer, heavier bikes use ally bottom yokes.
They'll be similar to BDK's yokes but less expensive- note I said 'less expensive' instead of 'cheaper'
Anyway, I'm after a bit of an idea for numbers rather than a definite yes or no, so, would there be interest?
				Re: Billet aluminium bottom yokes for 3TJ
				Posted: Mon Oct 10, 2011 3:40 pm
				by Evilchicken0
				Yup I'll have one
My forks get quite close to bottoming out on their road settings because I take a pillion.
				Posted: Mon Oct 10, 2011 4:05 pm
				by Kayla850
				Evilchicken0 wrote:Yup I'll have one
Cool! I'm just trying to put a Solidworks model together.
				Posted: Mon Oct 10, 2011 4:24 pm
				by Evilchicken0
				Kayla850 wrote:Cool! I'm just trying to put a Solidworks model together.
Sounds pervy
Maybe a lighter steering stem - although I suspect that will be expensive
				Posted: Mon Oct 10, 2011 10:38 pm
				by barryfzr
				Might be into a genesis one day if you get round to one
				Posted: Tue Oct 11, 2011 11:47 pm
				by KIYOSHI
				Yup would be interested in 2.
If you need any info let me know, got one on my race bike already.
Id go for 38mm depth, the 43mm bdk ones push the ramair scoop very close to the front mudguard.
If you are running standard soft forks you will also have to remember that there is a chance the yokes will touch the fork seals under heavy braking.
Oh and you hav a PM,,,,,,,,,,,,,,
				Posted: Wed Oct 12, 2011 8:30 am
				by Kayla850
				KIYOSHI wrote:Yup would be interested in 2.
Cool, thanks for the pointer! I've replied to your PM
				Posted: Wed Oct 12, 2011 2:05 pm
				by KIYOSHI
				I meant dust seals, not fork seals, it is common to see the dust seal removed from the forks when running BDK yokes.
				Posted: Sun Nov 20, 2011 10:11 am
				by drjkill
				im interested , but id like to see a preview and know if theyre going to be  very expensive...
				Posted: Wed Nov 30, 2011 8:35 pm
				by MrTadSlow
				After the New year I'll be interested Kayla.
