Billet aluminium bottom yokes for 3TJ
- Kayla850
- Bike owned: Sunn Tzar S2
I'm gauging interest for a batch of 3TJ billet aluminium bottom yokes to replace the awful standard cast steel effort. It'll be aimed at race/track bikes but there's no reason why they couldn't be used on a road bike, loads of newer, heavier bikes use ally bottom yokes.
They'll be similar to BDK's yokes but less expensive- note I said 'less expensive' instead of 'cheaper'
Anyway, I'm after a bit of an idea for numbers rather than a definite yes or no, so, would there be interest?
www.projection-racing.com
www.pjcfasteners.com
Re: Billet aluminium bottom yokes for 3TJ
Yup I'll have one
My forks get quite close to bottoming out on their road settings because I take a pillion.
- Kayla850
Cool! I'm just trying to put a Solidworks model together.Evilchicken0 wrote:Yup I'll have one
Sounds pervyKayla850 wrote:Cool! I'm just trying to put a Solidworks model together.
Maybe a lighter steering stem - although I suspect that will be expensive
barryfzr
Might be into a genesis one day if you get round to one
KIYOSHI
Yup would be interested in 2.
If you need any info let me know, got one on my race bike already.
Id go for 38mm depth, the 43mm bdk ones push the ramair scoop very close to the front mudguard.
If you are running standard soft forks you will also have to remember that there is a chance the yokes will touch the fork seals under heavy braking.
Oh and you hav a PM,,,,,,,,,,,,,,
- Kayla850
Cool, thanks for the pointer! I've replied to your PMKIYOSHI wrote:Yup would be interested in 2.
KIYOSHI
I meant dust seals, not fork seals, it is common to see the dust seal removed from the forks when running BDK yokes.
drjkill
- Bike owned: Cbr1000rr,Nc35,3TJ & Rg500
im interested , but id like to see a preview and know if theyre going to be very expensive...
MrTadSlow
- Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
After the New year I'll be interested Kayla.
