nc 30 engine bolt seized
im removing the engine from my vfr400 nc30. however the bolt in the picture (strangely labeled as A and B, as it looked one piece when i stripped it) is seized solid.
http://i52.tinypic.com/15p042a.jpg
its the right hand rear engine mounting bolt. the book says the adjuster (A) and mounting bolt (B) are seperate and should wind out together but when i looked earlier they seemed to be one piece. there is a recess for a 6mm allen key where the arrow (B) points i have tried turning this to the point where it is about to round, with no movement
however i have found this diagram aslo
http://i53.tinypic.com/2qdzxhg.gif
im pretty sure bolt 17 is the one in question, and it does show a three piece assembly including the lock nut.
however, as the bolt is not threaded until the opposite end to the head, should i try tapping that end of the bolt 17( i have removed the nut from the other side obviously.)
Thanks in advance
Thanks in advance
Re: nc 30 engine bolt seized
Welcome to the site..
I've taken my motor out this week,,,
the lower bolt - take that off - on the right had side of the bike.
This is a long shaft that has the slotted head and allen key mate with it.
If you are following the Haynes manual then you will not have taken out any of the other bolts yet?
You can drift this out and turn the allen key too...simples.
cheers mate that was my next step just wasnt hundred percent i wouldnt damage anything in doing so!! any parts for sale? rear tyre, speedo cable??
