Shim question
marti
Shim question
Post by marti »
Does anyone know if its ok to remove 0.1mm off 4 shims using a surface grinder?
Re: Shim question
not a good idea seeing as you can get them easy enough. They are hardened and so grinding this off is not cool.
What sizes you got and what do you need?
marti
Re: Shim question
Post by marti »
I need 5 2.16mm, nearly all of them needed doing.
Ive swapped all others round, ive got 2.22-2.35.
skinnydog0_0
Bike owned: Penny Farthing
Re: Shim question
Post by skinnydog0_0 »
CMSMJ1 wrote:not a good idea seeing as you can get them easy enough. They are hardened and so grinding this off is not cool.
:plus:
I wouldn't bother with the grinding either much easier to get new, or second hand ones the right size.
hunter
Re: Shim question
Post by hunter »
Shims are case hardened,if you grind them you brake through the hard surface,
They will then ware quickly along with the cams.
265chemic
Bike owned: 98cbr600f,08cbr1000rr,90vfr400
Re: Shim question
Post by 265chemic »
I recently checked my shims, engine cold, all inlets were in spec .12 - .18, but most of the exhausts had too large a gap (ie .30 instead of .21-.27, and a one had .33) Is this worth worrying about at this stage? I know having too small a gap on exhaust valves can lead to burnt valves, but as the gap is bigger im thinking only downside is a slightly noiser valvetrain.. is this the case?
